"Umm... that [i]is[/i] the ser
"Umm... that
is the serial number: 689-S-107165
By the way, the original question about the prop is a bit more complicated. Someone on the forum with a very similar motor/boat combination might be able to give some suggestions, but mostly it's just a question of testing how your particular rig runs. So there is no 100% "correct" answer as to what is the best prop for a given boat.
As far as I've understood it, here is the basic procedure:
1. Once your motor is set up and tuned properly, load up your boat with the approximate amount of people/weight you expect to have onboard.
2. Run it at full throttle and see what your maximum RPM is. For this, you need a tachometer (tach) - if the boat doesn't have one, you can hook up something called a Tiny-Tach, it's very simple and easy to use.
3. Compare your maximum RPM to the specification in your manual for your engine (usualy about 6000 RPM). The optimum is when you just reach that figure with wide open throttle. That means you're getting the most power out of your engine.
4. If you're achieving significantly less than the specified max RPM, you need a propeller with a lower pitch (shallower "screw angle" of the blades). If you're going a lot over the max RPM figure, that's not good for the engine either, so you need a higher-pitch prop.
Note that the RPM you get (and thus the ideal prop) will vary a lot depending on the weight load you have in your boat. For example, on my 13-footer (pictured), I usually run a 9" pitch prop, but switch to a 6" pitch on fishing trips with 2 people, heavy camping gear, extra fuel etc.
Propeller selection is an endlessly complex topic that can encompass a ton of other factors but for smaller outboards the prop pitch is the most significant variable as I understand it.
There are plenty of decent articles on prop selection you can find by googling, for example this one:
http://www.evinrude-parts.com/boat_propeller_selection_article.html
"Prop selector" calculators such as this one may or may not be useful... personally I've yet to get any sensible info out of these but might be worth a try:
https://appcenter.mercurymarine.com/propSelector/home.do"
