Howdy Guys.......between vacation and other things, it has taken me a month to get back on this job. I got the heads back on and torqued, but I didn't get to finish the angle torque for lack of a 3/8-1/2 adaptor. So torquing isn't quite done. Maybe this will save my bacon. What I did wrong was......I put the heads back on without making sure the crank TDC was synced with the cam pulleys TDC. So far there isn't a conflict because all the valves were seated flat as I got them back from the shop.
But as soon as I turn the camshafts the valves will contact the pistons. There must be a method to this, but I can't think of it and I don't see anything in the manual that explains it.
I assume I have to back out the heads 1/4" so I can get the valves lined up (once I know how to do it) without conflicting with the pistons. But does that just ruin my brand new head gaskets? Can they be re-torqued?
Anyway, if I can get someone to explain how to reassemble heads to block, in sync with the pistons I'd appreciate it. And also, can I reuse my new head gaskets if I back off them?
