dawilson76
"I have a 1977 Chrysler 360 th
"I have a 1977 Chrysler 360 that begins to have a little white smoke out of the the stbd exhaust after running at idle for about 10 minutes and then doesn't stop smoking. The engine is in a project boat so I can't take her out so I don't know what it'll do under load and higher rpm's. It is raw water cooled and doesn't seem to be missing or idling rough. Does anyone have a suggestion on what might be causing this? I know that it's probably water causing it (white smoke) but if water were getting onto a piston, I would assume that it wouldn't run so well at idle.
David"
David"
