Hey everyone I am having problems putting my lower unit back on my 72 9.5 sportwin. I just serviced the gear box and am trying to get it back up in the housing. I am having problems with the shift linkage. What gear does the box need to be in and what gear does the handle need to be in? I finally got it close to where the box is in the high position or foward and when I connect the linkage and pull the handle down to foward position it sucks the lower unit upward like it should. My only problem is there is a quarter inch gap in between still with the handle all the way down. If you look at the gear position inside the hood where the throttle is the lever is in the nuetral position but the gear is in reverse and foward postion is only nuetral and if you hold down the lever you can get it to foward but it pops out. The gear box shifts fine there is nothing jamming it up. something is wrong with the linkage arm in the house is there any way I can adjust the positioning?
