This motor has been completely
This motor has been completely redone. Everything is new other than the rectifier which was replaced a few years ago after being fried by an onboard charger.
Power is down a little and wot rpm is 5700-5800 with the same prop that used to go to 6400+ if I let it.
I have gone through the entire fuel system from tank pickup to intake and everything checks out OK. Vac switch is working. One carb float was a little misadjusted.
I put the timing light on each plug wire while idling in gear and it looks like there is an occasional miss in 5 of 6 cylinders. I repeated this several times and got the same result. Only the one cylinder(starboard bottom) looked to be firing perfectly on each trial. Is this possible?
