wynjim55
The answers to my questions on this forum have helped me to rectify a number of problems with my 1978 Mariner 55hp 2 cylinder outboard (Yamaha built), I am thankful to you all for your advice and knowledge.
I've now had this outboard for over 12 months so I'm getting to know it fairly well. It runs well, even starts easily now thanks to some good advice from here on running the engine dry of fuel after each use. I've recently replaced the battery leads to the starter motor and it winds over better than before. I have previously cleaned and rebuilt the carbs and fuel pump, and replaced all the fuel lines (tank connector through to carbs). The charging system is operating well. There is however one persistent problem.
After having been running well and coming back to say a boat ramp, it struggles to maintain low revs for a controlled approach. If I'm quick enough I can go from forward to reverse but I have to keep the revs up a little immediately after the change, same too when I go from reverse to forward again. It makes for some rough changes given that I can't operate slowly. What am I looking at here? At times it struggles to maintain idle before heading out, yet in the driveway it will idle nicely until starved of fuel (causes me to think the idle speed is good).
