junior4597
I just purchased an older model Tiara with twin 350 IB's recently. Compression tests all went fine with the pre-purchase evaluation/survey and both engines had been tuned up, oil changed, plugs, wires, cap etc. I ran her about 5 times so far until yesterday when the port engine at idle started to knock a little and started to stall. I powered up a bit and she was fine but at about 2500 rpm she started to bog down and I could smell a strong odor of fuel. At about 1000-1500 rpm she stalled a few times and I had to crank her over again. She kept stalling at any rpm so realizing something was up I turned her off. I'm at a loss but here are some things I have done and am looking for possible suggestions on next steps.
I was thinking that it might be time for a carb rebuild but I'm not sure. I'd hate to have it removed and sent out if that's not it. Is there anything else I should check and or thoughts from the forum on next steps? Hard to evaluate from reading this but any bit helps!
Thanks!
- She was sitting for 3 years prior to my purchase but the old fuel was removed (supposidly) and fresh gas put in.
- No fuel leaks in the bilge
- New commision tune-up a month ago
- checked the fuel lines for brittle or cracked hoses - none
- looked at the fuel filter, seemed clean, no residue or water on the bottom of the can
- no blockage in any of the lines
- fuel pump is fine as the carb gets fuel - but maybe too much??
- used gum-out to clean the carb chambers
- removed 2 plugs to see if there was excess fuel on the ends, all looked good
- the carb seems to be making a louder sucking noise than the sb engine which seemed like it was fighting abnormally for more air??
- flame arrestor was clean
- choke and mechanics of the carb seemed to be in prefect mechanical order
Thanks!
