papahambre
Hello Gentlemen, I have been working on tuning up a little mercury 4 hp trolling motor. I've completely disassembled the carburetor and installed new fuel lines. I was going to install a new fuel pump kit (new gaskets and diaphragm) but ended up getting the wrong ones so I checked the old ones, cleaned them and reinstalled the originals. They looked fine. I hooked up the motor to the fuel tank off of my boat using it's line and primer bulb and it started after a couple of cranks. I ran it for a little while then started wondering about the impeller because I didn't see the tell tell spray and it started to heat up. You guessed it, the impeller was trashed. I installed a new impeller and it runs like a fine tuned cat now, except for after awhile of idling, it starts to idle a little sporadic then quits. It is almost like I am losing prime. Any ideas on what to look for and how to fix the problem?
Thanks, Papahambre
Thanks, Papahambre
