Looking for original exhaust manifolds for 2 Riva Crusader engines, build 1986-1988.
Hans57
Hello forum members,
I am in the process of rebuilding two Riva Crusader (General Motors 305) engines.
Model motor 210, V8 small block, build 1986 -1988, 210 HP
Casting number on the block is: 14088551
I am looking for four Genuine Riva copper exhaust manifolds for these two engines.
I know these are hard to get, maybe someone knows another solution in case I can't find them anymore.
Parts will have to be shipped to the Netherlands.
Any help is highly appreciated, thanks.
Regards, Hans
I doubt that you will find them over here...maybe within the EU somewhere?
As for the alternative, I would suggest a center riser design with the elbows to match...you can them plumb them as you desire. Over here, you can get them from Sierra, BARR, & Mercruiser....if cost is NOT an issue, you may want to consider the newer Mercruiser Dry-Joint components...
