I am trying to perform a Link and Sync on a 83 OMC V4 115hp eng. With all of the linkages (cables) disconnected I am unable to get the throttle arm to remain in the idle position so that the idle adjust screw will come in contact with the contact point on the eng. case. Something seems to be pulling the arm to the full throttle position. Should there be a return spring that holds the arm in the idle position or is this a function of the throttle cable? Eng was rebuilt and I am not sure everything was put back together properly.
