"Patrick - there are empty bol
"Patrick - there are empty bolt holes on the ends of the heads (factory hooks were often bolted to in these areas). Connect the chain to the front of one head and rear of the opposing head and it'll be fairly well balanced. Make sure you place a couple of heavy, large diameter washers between the head of the bolts and the chain link that you insert the bolt through.
Keep a close eye on the mounts when you begin lifting the engine. You want to be sure the motor is sliding freely off of the mounts. If there’s any binding or tension you could end up yanking a mount out of a stringer (or whatever they’re secured to in your boat’s structure)."
