J
Jason Schneider
Guest
I m new to the boat world i h
I m new to the boat world i have a 235 horse johnson i replaced the water pump and whe i pu it on water cups it leaks water between the gearcase and its matin surface is ithin ok? Also the water pump housing has a hole in it it from the factory is this for pressure relief. I was told no gasket is need between gearcase and bottom of engine is this correct. Thank you jason
