This 1985 20hp Johnson I got last summer is keeping me busy.Learnig a lot.This engine makes a noise that concerns me somewhat.Not sure what it is.The engine seems strong after using it last summer a few times.I did hear a noise at slower speeds I was not sure about and here at home running it on muffs I give it throttle, say above idle or half and and I hear a knock or something and see engine jerk like a miss,sounds like a metal sound but not sure, but it does not seem to do it at full throttle and seems fine at idle and do not hear it.Is this a miss?I have recently readjusted the slow speed screw due to having to replace the plastic retainer for it.It is set at about slightly over half open and all linkage adjustments are correct and had put new plugs in it after I bought it last summer.I do not have a compression gauge to check that, but may try and source one.Not sure if this could just be a lean issue and need to adjust it more?Not sure if running it on the water would make a difference or not.thanks
