carl_olson
My girlfriend inherited a 1990 Crestliner Phantom V170 with a 110hp Johnson VRO V4. I believe it is the original engine but I could not find any information about it. I do know that it was rebuilt in 2015 and the cylinders were bored out along with a replacement of the impeller and carburetor. I redid the floor and replaced the old circuit panel with a modern one. I also installed voltmeters above the batteries. The deep cycle is brand new and the starting battery needs replacement. It only holds to about 12.0v. I also installed a brand new battery isolator.
So the starting battery is at 12.0v and the deep cycle is at 12.6v. When starting the motor the battery drops to roughly 10.0v then after it is running it goes back to 11.9v or 12.0v. The Tachymeter is working and even when I push it above 3k RPMs it stays right at the 12.0v mark. I have tried both batteries together. Both of them individually. I tried the old battery isolator, the new one, and even just straight to the battery. Nothing changes. I have a wire coming from the #4 on the bus bar in the motor housing to the positive of the starting battery.
I have worked on cars for many years and do some electrical at work. But I am really new to outboards. I am looking for anything that I can do to help diagnose this issue.
Thank you in advance!
