95 Evinrude 225 strange problem. When I lower the boat in the water from the lift it starts and idles fine. Can idle out thru slow zone and accelerates up on plane just fine. I run about 25 minutes to my fishing spot. Shut motors off. Fish for 3 or 4 hours. Motors start and idle fine, the problem is when I go to take off one of the 225's will stumble and stall. The RPM's go to about 1100 then it stalls.
Restarts right up and idles every time. I can go thru this scenario several times and eventually it act normal and runs like a champ. And once up and running it runs great. Yesterday I primed the choke with the key and my son was squeezing the bulb, this seemed to help. Though need more testing may have been a coincidence.
Only happens on one motor and only when the motor has been warmed up. Never happens when leave the dock for the first time. I have done the lynk and sync procedure, I installed a new power pack. Cant understand why it only happens after it has been warmed up, that is what has me confused.
Any suggestions and why it would only happen once warm?
