"I'm lost and confused...
I have 60 HP johnson 1970, 3 cyl.
Bought this motor a month ago with a boat. Previous owner said the motor worked like a charm...
Well, initially (when i had the boat finally home) I couldn't make it run at all. Then after cleaning/rebuilding the carbs she finally fired up!!! But wouldn't run on all 3 cyl's. That's when I decided to also take a look at the distributor side ... Took the whole distributor assembly apart ... Definitely it needed SOME cleaning ... Put it back together ...
Now I experience the major issue - it fires right up, (in the bucket of water) it ran perfectly smooth without the prop as I revved it up in the gear the day before yesterday ... But when I put it in the water yesterday (with the prop) it died as after couple of seconds or so when in gear.
Removed the prop and put in gear worked like a brand new motor! I'm at major confusion point here.
Can some1 help please?
One guy suggested that a bad distributor adjustment might be causing that behavior. Is it possible that I have dislocated something when I took the distributor assembly apart? But it seemed like I put everything back to its original positions."
