Johnson 70 hp gas restriction to carbs
ricc
"Hi, my problem seems to be th
"Hi, my problem seems to be the gas pump,(vro)?,I've changed the hoses and fittings, everything but the filter, is the gas pump serviceable?
Thanks!"
"check the filter,replace as n
"check the filter,replace as needed.
vro pumps are serviceable/rebuild kits,you would just be better off replacing the whole thing."
