Johnson 6 horse Impeller replacement
retals99
Anyone have some advice or ti
Anyone have some advice or tips to replace Impeller. I've taken off 4 bolts and unit does not drop down. What's the trick ? Trying to replace with new impeller
"Retals..... Put the unit in r
"Retals..... Put the unit in reverse. That will let it drop down enough to remove one of the 3/8" hex bolts from the brass shift connector.
Joe
Thanks for the help.
OK got
OK got it down and replaced Impeller and put back together. Just so I'm sure can you give your advise or general idea when engine is running in water how much water should come out of water discharge outlet? Is a mist ok or should more come out? Thanks
"Retals.... Water should exit
"Retals.... Water should exit the water outlet, that exists about halfway down the exhaust housing, with a strong flow. If you're only getting a mist, you've still got a problem.
Joe
