steve_johno
"johnson 55 i bought a few mon
"johnson 55 i bought a few months ago had proplems with the gear shift, i sorted all that out thanks to joe,
while i was at it i checked the waterpump, even though it pumped plenty of water to begin with. dismantiling the waterpump seemed to destroy the existing gaskets, the impeller seemed in really good condition though. so i just used some gasket sealant to replace the water pump seals.
the next day, i put it all back together stuck the watermuffs on the inlet holes with the hose on full and fired it up! to my amazment there was only a trickle of water running out from where it should be squirting out.? so i turned it off and took the lower end of again. tested for blockage by puting the garden hose on the lower pipe. water was flowing out the overflow tube ok but not the outlets? .should i take the side panel of it and check the thermostat? any suggestions would be great, Thanks.
