Maxanoava13
Hello. I have a 1968 Johnson 40 outboard. It will crank over all day long with the throttle closed, but stops cranking with the throttle open. One wire on the solenoid has no power when cranking, and has power when throttle is moved. Is there a sensor under the flywheel? I'm lost at what could be causing this.
