I have a 1984 35hp Johnson. It has quit charging. I need to find a way to test the stator to see if it's putting voltage to the rec/reg assy. I know on a Mercury, you test the 2 stator wires coming from under the flywheel. It puts out ac voltage. This stator wiring seems to have 3 wires and i dont wont to burn anything up. Also when the battery gets week the boat will not run wide open. Could this be caused by lack of voltage as well? Thanks for your help.
