Hello
I have a 1990 johnson 30hp outboard which has troubled me for a few days. A few weeks ago I turned the flywheel by hand and noticed that de movable plate with the ignition moved as the flywheel passed by it. A few days ago i took the flywheel of en there was some evidence of something touching so I adjusted it and it seems to be better now. However when i disconnect the ignition from the throttle lever and turn it to full advance. (fully anti clockwise when viewed from above) it rest againtst the stop. But every time the flywheel passed it moved back about half an inch from the stop and then stayed there when the flywheel passed again. I have been stuck with this for days. But today I thought I knew the answer. It only moves with the layerd coil, Not the powerpack, When i removed the coil it didnt move so i though it must be touching the coil. But is it possible that the ignition plate is pulled back because of the magnetic field that is generated when the flywheel moves along the coil? If this is the case than there wouldnt be a problem right? Because in normal operation the thottle arm keeps the plate where it should be. and it wouldnt be touching anything anymore if it is just a magnetic effect?
And does it matter how close the coils and powerpack are to the flywheel? or doesn't it matter with electronic ignition? Because i have been told that with electronic ignition on an outboard as long as you have a spark it's fine, unlike the old points system where everything has to be checked with feeler gauges etc.
Any insight/help would be appreciated.
Kind regards Rimmert
