so first off as said before I'm not an expert, So as to your question " I will not damage anything if I test the 15 hp power pack?" I DON'T KNOW 100% .
CD2 for me is the power pack, on my motor(1987 48spl)the ignition is 5 basic electrical parts, spark plugs, coils, charge coil, sensor, and power pack.
your 15 and 30 has only 4 parts, s-plugs, coils, charge coil, and power pack. note: best i can tell 1989 the sensor and power pack were combined in one unit and put under flywheel like your 2 motors. 2 cylinder motors have some same parts as you have said and used. power packs have change like adding rev limiters, and slow mod's( if over heated or no VRO oil, rev limited to under 2000rpm's to try to save engine) on this site the power pack for your 30hp has this info from OMC, description reads " [FONT=Verdana, Arial, Tahoma, Roboto Regular, Geneva, Lucida Grande, Helvetica Neue, sans-serif]These kits provide a method of eliminating wire abrasion and possible damage to the ignition module on 1989 thru 1991 4 thru 55 HP Evinrude and Johnson outboards." this leads me to think it would work , but its your call [/FONT]
[FONT=Verdana, Arial, Tahoma, Roboto Regular, Geneva, Lucida Grande, Helvetica Neue, sans-serif]some of the senior contributors may chime in soon, the same guys from that other forum.
[/FONT]HELP!
