" ok i have a 1984 evinrude v4
" ok i have a 1984 evinrude v4 vro . now just the other day it started acting up on me . it ran fine all day , then we anchored to go fishing an i guess maybe an hour or 2 later when we started it back up to go home, it started . it seems to be sucking itself dry . i have to keep pumping the primer bulb in order to keep it running . we limped it home . after a few minutes of running the bulb is empty , thats when you have to pump it to keep the engine going .if you dont pump it it boggs a little, then dies out . i have a full tank of gas so thats not it (lol) , i checked out the fuel line , no cracks or splits , i just rebuilt the carbs so thats ruled out , replaced the check valves on the intake manifold , so i have no idea why this motor is doing this . did i break a reed valve ? if i did that it probably wouldnt start though huh . but know gas is getting to the carbs fine but after the gas you pump in there burns out thats it the motor dies . i need the boat for the fourth of july please help me with this one . its probably a common problem and you know what the deal is . thanks in advance "
