Model no- E150GLEOM. 1995. Motor is on javelin 379 t. I can’t get on plane well. It bogs down. Once it gets up I trim up and can get more rpms but can never get over 4000rpm and 44 mph. Good compression. New cdi power pack, coils, plugs that are recommended for cdi power pack gapped at .030, cdi
recommended plug wires, optical sensor test shows it’s good, stator tested good on dva meter, new clear cam roller, Jerry’s easy timer to set timing, jackplate to bring engine to 3.5 inches below pad, 24p raker, timing roller in proper place, high speed orifices properly seated in all carbs, replaces cracked manifold, manifold gasket, and all related o rings including spaghetti one. Problem was the same before all this work and still the same after all this work. I pushed the key in to choke it while on plane today and it bogged down which is supposed to signify an electrical problem. What should I check now?? So lost and frustrated
