I've got a 1989 Evinrude VRO that's had ongoing issues with sudden, erratic bumping/jerking while under load. It feels as though the engine has shut off for a split second, then re-engages. It can be quite jarring, as it is unpredictable, aside from it only happening while on the water. It almost feels as though I hit something. Never happens at idle, although it started off only happening at wide open throttle. Now, it happens at various speeds.
Sometimes it will happen a couple times and not do it again the rest of the day. Some days it doesn't happen at all. Others, the engine will suddenly shut off while driving and not restart. It still cranks, though. What's strange is it will fire up again on muffs pretty much as soon as it gets home.
Yesterday, it shut off and left me stranded. I tried to restart it, and it suddenly stopped cranking. It would only click once. I get it home, and realize that the starter motor has jammed the flywheel (This is the first time this has happened). I unjammed it, and it immediately started up. I took it out on the water again, and it worked fine, although I didn't really push its limits.
I've cleaned the carburators, replaced the fuel filter, bulb and the spark plugs. I checked the carb bowls for water and there was none. I also replaced the fuel pump, as it was bad. I didn't think this was a fuel issue, but I hoped that would solve it.
Seems like it could be any number of things, but I'm stumped.
