I have a 1972 Evinrude 50 hp while in neutral idle speed will kick into forward gear. Battery is a full 12.7 volts, both solenoids check out at 6 ohms. I have had some evidence of water in lower unit but change it faithfully. With fresh lube in the unit I started motor in the water to set carbs as I just put kits in and not two minutes after start up motor kicked into forward for about thirty seconds then back to neutral and did so the entire time in the water. Back at garage I drained the lower unit and no visible signs of water. Any thoughts?
