missnancy
I have an intake manifold on my 350 which was originaly off a 283. The reason I am using it is due to the fact that instead of a single gooseneck for the cooling hase I have two of them. One on each side of the intake. The coolent reservior mounts where the gooseneck would have been. The problem I have is the only carb I can use is a rochester 4 jet which has the same size main and secondarys. The manifold is drilled to accept ithe 4 jet. I can bolt on a spread bore carb but the secondarys will not open as the holes are to small.
That said, can I take the manifold to a machine shop and have them bore out the secondary holes without a problem or will I cause a whole new set of problems. I cant use an adapter plate due to clearance in the engine space. Thanks in advance for the help guys.
