Installing gauges
chris_v
I would like to hook up a temp
I would like to hook up a temperature gauge and water pressure gauge to my 79 150hp. Can I get instructions on where to connect to the motor?
The water pressure gauge goes
The water pressure gauge goes to the 1/2" plug in the top cener of the block. There may be a bypass hose already there to tee into.
The temp gauge orignally had a flat metal tringaluar plate bolted to the head that was tapped to accept the sender. There was a heat sink pellet that went in the hole. I do not know if you can still find these parts.
