Chris Williams
I had a beat up 4 blad prop and wanted to get a 3 blade which folks seem to like better for my boat. I remove the old prop easily, there was grease there which was good, cleaned it completely out, and installed the new prop on top of the exisiting thrust washer. The prop came with a spider type nut, but the original used a washer and then nut and cotter pin so I did that method, tightened it all up, and it runs great BUT when I firt go from like 0-6 mpg there is a distinct whine or almost howl. Doesnt happen in neutral and the gearbox seems ok, I have changed the fluid in it twice in past month to flush it out and used Hondas final drive fluid.
Very odd since it never happened with the beat 4 blade, but it doesnt sound right to me
Also is it normal that the thrust washer wouldnt come off by hand? I think the book says you need a puller and I didn;t do that so maybe i need to? thank you
Chris
Chris
