B
Brian Sinclair
Guest
"Crusader 454's with Roche
"Crusader 454's with Rochester carbs
When I put the port engine into gear, the RPM's drop and the engine stalls. When returning to dock, I had to run the engine at 1000 RPM when not in gear. As I placed the boat into gear the RPM's dropped to 700. This worked OK for docking, but this is the first time I've had this issue. I warmed the engines up for about 20 minutes. Any Thoughts on cause?"
