H
help
Guest
I have a 2001 90 hp johnson th
I have a 2001 90 hp johnson the compresson is 120 +or- 5psi the spark looks good but the port side 2 cylinders I can take the plug wire off 1 cylinders at a time and the idle does not change if I do that on the right side the motor will die also if I only throttle the port side the rpm do not change much.any ideas motor heads?
