Idiling to high
BrodeClark
I have a J150TLCIH that is idling to high. The butterflies are completely closed. The throttle cable is disconnected at the motor. Done the link and sync according to my manual. I have also installed a new timer base, new power packs new primer solenoid and new carb kits. When you start it up it runs 3000 rpms.
have you tried blowing propane or spraying carb cleaner or other flamable material in and around motor / seals to see if you can find an air leak? OBVIOUSLY DON'T SPRAY NEAR CARB WHILE RUNNING!
