Stefanek821
I bought a bass tracker TF 16000 1989 with two mercury outboard motors, one is 2005 optimax 115 hp two stroke and second 9.9 four stroke. In the 115 hp i changed the gas filter and air filter, and in the hull I changed fuel water separator filter and also i put new gas hoses. After finishing I try run engine small 9.9 starts with no problem but the 115 don't. I checked and there was no fuel in the line so i pomp primer bulb and fuel goes to the engine , but still the engine didn't start. what can be wrong?do you think can be air block?
