buckz6319
I am back again, with a different topic
I have purchased a 1984 sea ray with a Mercruiser 140, complete boat, engine is running and everything works
The engine is original, even the manifold, and riser. The po said it started to run hot a few times, but when he shut her down, and started her back up, she ran fine.
I did some test before i purchased the boat. The compression was 148-150 on all 4 cylinders. The spark plugs looked like she is running normal.
The out drive worked, and water flow appeared to be good. I unsrewed the drive drain plug, and black thick oil came slowly out, but no water.
I think she has a bad gimbal bearing, or coupler, or both. The entire stern vibrates when engine is running, seems worse at idle, than at higher rpms.If i put pressure with my foot on the engine( like I was trying to push it over) while she is running, the vibration is much worse.
We had her running for 45 minutes and the temperature gauge did not get above 140ish, and the gauge may not be accurate.
The po has owned this boat for 20 years, and gave me as much info as he could on the engine, and boat.
So now after making a decision to purchase her, I need help in doing a swap, after I am ensured that the heating issue will be resolved.
What will swap over, what will not swap over, should i do a total engine to drive swap
I would appreciate your help...
Thanks!
Thanks!
