Masterbcobb
Trying to remove the transmission coupling from the prop shaft. The coupling has two set screws and a shaft key. After loosing the set screws, I tap on it with a hammer but it dose not move. Is there a tool, or a technique that is required to remove the coupling from the shaft?
