I have the lower unit disassembled. The O ring at the top of the shift rod needs to be replaced. To do this I need to remove the shift rod bushing that sits above the o ring. I can't get at the bushing with a drift from the bottom, it looks like the o ring sits in a cavity and must go in or out from the top, after removing the bushing.
I observe the bushing is peened into the aluminum housing. I have already done some damage to the aluminum trying to get it loose.
Any one done this removal before and care to advise?
I don't want to do any more damage. I am thinking about applying a little heat.
