How to remome impeller
R
reytumamao
Guest
" Hello, I would like some hel
" Hello, I would like some help on removing an impeller on a johnson 30hp and would like to know how to check if thermostat is working
thanks
Rey "
" Rey,
I could explain this t
" Rey,
I could explain this to you in detail, but If you have no idea, I would recommend you purchase a service manual. This will give you full details on this and many other common procedures required to properly maintain your motor. Good luck.
Rick "
" Hello, I have a 1999 50 HP H
" Hello, I have a 1999 50 HP Honda 4 stroke outboard motor. The overheat warning is coming on. There is a steady stream of water flowing out of the motor, but not high pressure. The water is pretty warm. Do you think it is a bad sensor or a bad impeller? Can you send me a drawing or tell me where the impeller and sensor are?
Thanks,
Monty "
