how to hoist a 2004 Johnson 175 outboard engine?
TheBrain
I want to lift a 2004 Johnson OB engine how is this done?
I see a bolt ontop of the flywheel is this the lift point?
Thanks TB
Don't think so.-----------Take a really good look around the block.----------Then I think you will see the lift points !
OK I'll take a closer look.
are you saying there are empy threaded bolt holes on the block? and will they be under he heads?
Thanks TB
I found the triangle hook on one side of engine the engine is lieing on the ground right now so I assume the other lift point is directly on the other side the triangle was hidden by a bunch of wires glad I don't have to buy a $40 bolt
TB
