I see the connections on the side of the block and the lettering next to a connection:
=open = Nada
O=O "start"=Yellow=connection from key switch yellow?
O=O generator=purple= do not know
O=O open=Nada
O=O tachometer=white=gauge not purchased yet
O=O choke=Green= do not have this option on the throttle control so a toggle sw?
O=O temp/heat=orange=gauge not purchased yet
O=O battery=red= I assume a lead from batt?
O=O ignition=blue&small red wire= connect from key?
O=O ground=black=ground plane
O=O forest green=?
O=O circuit reset=Red & Red/white
plus I received two Bosch relays 12V 20/30A each has five leads.
Each has a red/bl stripe lead that are tied together at a eyelet connector = ?
Each has two black leads tied together individually at a bigger eyelet ? battery type?
each has two colored wires #one blue&bl/wh, the other green&grn/wh ?
I have a key/switch with 6 leads coming from the back of the sw going into a harness that was as I'm told to this motor?
I guess a schematic or two might help.
Thanks to all that have gone before...
=open = Nada
O=O open=Nada
O=O forest green=?
