Rmm,
Yes, as Mark says you should use a large wrench to hold the filter housing nut in place while removing the fuel line with that flare wrench. Then when you remove the filter housing large nut be careful to note the order of the contents for reassembly. The boat owner next to me at the marina installed the filter reversed and it caused him all sorts of problems. When troubleshooting the ensuing problem, he removed the carb and, to check the fuel flow from the pump, he cranked the engine which started (enough gas and fumes in the intake manifold) and sucked the rag he had covering the carb holes into the manifold and almost into the intake valve of one cylinder. He didn't know that the rag had gone into the manifold but discovered that the filter was reversed, so reassembled everything and the engine started OK but there was a rattling noise coming from inside the manifold. He thought that maybe a socket or some metal object had fallen into the manifold, so he removed the manifold only to find the rag partially under the intake valve. He is now in the process of putting it all back together again.
Good luck!
Erich
