"I just recently took apart my
"I just recently took apart my lower end and would like to replace the pinion to drive shaft bearing. Is there a way to removed it out the prop hole? or is it put up out of the drive shaft? Also do I need any special tools? Or can I just rig something up??
Turn out my clutch dog is worn out and needs to be replaced, gear set looked good, with a little roundness, but can still use for a while till I find a deal on ebay.
Also is there a trick to shimming up the drive shaft with out buying a shimming tool??
Larry"
Larry"
