I "rescued" an 8 hp Honda outboard, pre 97. It had been submerged in salt water and left laying on the beach for who knows how long. I got it started and it overheated instantly. I turned it off immediately and tore into it. This covered that the salt and clogged all of the cooling passages. When I attempted to disassemble the power had the nuts and bolts were so hard to remove that I ended up breaking the head. I checked out the rest of the frame and was able to get all the cooling passages clear. I bought a 10 horsepower power head. I installed it and bought all new electronics due to the fact that it was a point ignition system. The eight horsepower power head with a CDI ignition system. The only thing that was not new on the 10 horsepower was the flywheel. I checked all the wiring, all other specifications, we timed it to factory specifications. It would not run. I set up a manifold to test the plugs outside of the head and I got sparks. I reinstalled the plugs into the engine and it still would not run. I removed the plugs and introduced a few drops of gasoline into the cylinders then reinstalled the plugs and I would not start I remove the plugs sprayed starting fluid into each cylinder, reinstall the plugs and it still would not start. I checked the magnets in the flywheel to be sure that they still had magnetic fields. They did. I then checked online to try to find out if I required eight different flywheel for a point ignition system. I read across many sellers that indicated they have a flywheel for a 7,8 or 10 horsepower Honda. I noticed black flywheels were for the.ignition system I noticed bread flywheels that indicated they were for the CDI ignition system. The flywheel that that was with the eight horsepower frame was black. I have checked and rechecked all the wiring checked and rechecked all the specifications for the different parts that are on the power head. Does anybody have any information for me at all? Any good guess's? The number on the power head is B 100 -1000 -820, the Honda frame number is BACL 1000542 mfg (1987), and is commonly known as a BF8A. I have found that the only difference between and seven and eight or 10 horsepower is the cam.
Thanks in advance for any help that anyone can get me I am at my wit's end.
