hurricane oz
Hi all. I have a 2019 BF60a LRT that is driving me nuts overheating. It runs fine at idle or very low speed (under 2500 rpm) but when you get on top, after 100-200yds the overheat alarm goes off and drops the rpms. It shoots out a great stream of water.
I have replaced the thermostat, water temp sensor, entire impeller kit, checked the intake screens and run de-limer through the cooling system twice. None of that improved the problem. At first it would run fine up to 5000 rpm before overheating- over two weeks time that has steadily dropped to 3000 rpm before overheating.
Something that seems odd to me is after the overheat alarm goes off and I turn the motor off, I can start it up again immediately with no alarm going off. Doesn't seem like it would cool that fast.
At this point I don't know what direction to look. Thanks for any advice/info
