Shane Gibbs
Hi Honda spe******ts
Im brand new here and hoping you can help me out with some problems on a Catamaran with twin BF135A outboards
I have just purchased this boat in a not going condition. Apparently it had engines swapped some time back, used Hondas fitted ( 800 hrs ) complete with new looms and remotes. I have conflicting stories from the previous owner , from documentation i have obtained and from a dealership who did some work on it.
Seems it has hardly been in the water in the 18 months since the engine swap due to alarms and engines going into "limp mode" and no one has been able to figure it out. From what I can gather it sounds temp related
I have a lot of question but think I need to start with the basics...
I haven't run the engines up yet but have noticed that the oil light on one of the remotes stays on with key in the on position and does not flash on for a few seconds and go out like the other side does.
Is there a starting point where I can diagnose this problem? I have cleared codes by cycling the ignition and got the all clear beeps once done but oil light still stays on. I would like to hope that by fixing the oil light issue it may also take care of other faults that will need to be addressed once done full start up and check over
Any help would be appreciated.
Cheers
Shane
Cheers
Shane
