Worldcat2000
When trying to start all cylinders get flooded out with in 2 secs of turning key.
is it the fuel pressure regulator?
It sounds to me like the Idle Air Control is not working. At startup, it allows additional air into the intake and slowly decreases it to bring the engine from the fast idle down to an slow idle as the engine warms up.
It could be the IAC itself, connections, wiring, or ECU.
You can remove the IAC and clean the screen on it. It may just be carboned up, blocking any additional air from going into the intake. Spraying it with brakleen or similar solvent should clean it up. Part # 26 https://www.boats.net/catalog/honda...l-range/130hp/bf130a3-la-2003/intake-manifold
You can also, take a couple of small jumper wires and apply 12 v intermittently to the contacts in the connector and the little plunger, inside, should move back and forth. If it does not move, then you definitely have a bad IAC.
Hope this helps.
Mike
BF130 has no pulser coils,has a relucter wheel and crank angle sensor. The map sensor can cause flooding at start up if it has failed, try that.
PM sent.I pulled the black cover off and found the red plug stuck a paper clip in it and turned the key on and the only thing I got was the two second light on both motors.
Did I do it right?
i also swapped the map sensor and its still acting up.
3-part#35673-ZW5-003 SENSOR, WATER TEMP 4- once I got it out it actually broke in to two pieces and was corrode in the middle. 5- I think I changed almost everything that had to do with fuel and spark related. its still hard for me to believe that a water sensor has that much to do with fuel and timing. What got really frustrating was when the dealer could not find the problem after 3 weeks. Lol |
