Hi guys,
I bought a cheap motor with a replaced head gasket and resurfaced head from the previous owner. I've read that the oil filler neck must be replaced and also replaced the crankcase gasket , thermostat and thermostat gaskets with new OEM.
I've cleaned the engine and started it.
For 2-3 minutes of run time the oil got milky and there was about 50-100ml of clean water which exited the drain before the actual milk.
I guess that the engine was heavily overheated as I see small amount of scoring on the two cylinders.
Is it possible that the block has been warped or cracked? The water was a lot.
Any advise how to test it is welcome !Head is currently removed.
Thank you in advance
