first hello to everyone , i am small marine mehanic from serbia.....i need some help,i apoligize in advance if my english is not perfect
i have old honda b75 but CDI model, after 1/2 of open throttle green oil chek lamp is dies , on idle its ok , i messure the pressure of oil with gauge and its about 45 psi on idle and open throttle , so the oil pump and strainer should be ok as the engine has good pressure by messuring in all mods , when i take out the wire from oil pressure switch and put it dierctly on ground (negative) the behevior is same , green light is on to the half of throttle after on more speed its dies....pls help
