I bought my father In law's Boston Whaler with a Honda 90 4 stroke last year. I left it with a Dealer to winterize, store and do a tune up because the Honda had a little hesitation on acceleration. On our summer vacation it ran great but after 30 minutes it started sputtering and would not run at high speed. I checked all fuel lines for leaks and pumped the fuel bulb. Pumping the fuel bulb helped a bit but the motor did not run above 4000 rpm. I foolishly forgot to check the air vent on the gas tank. I have never closed it. The Dealer must have closed it. I needed a wrench to open it. After that the motor would run for 5-10 at top speed 7000 rpm but then drop back to 4000 rpm max. The Dealer said that the high pressure fuel pump was the issue. I can imagine replacing the high pressure fuel pump is expensive. I didnt run the motor more than an hour or so eith the vent closed. It seemed to be running better after I opened the vent. I'm wondering if the fuel pump is damaged or just stressed? Will it fail? Should it just be replaced?
