"I have twin 1995 Honda 50 hp
"I have twin 1995 Honda 50 hp motors with the port side starting up fine and idle. When I run it for about 15 minutes under load and I stop (idle), it idles fine for about a minute then the idle drops and it dies. It has a hard time starting, and when I finally get it started and when I put it in gear it dies. I will have to start it and try putting it into gear several times, and once I get it going it runs fine under load until I stop again. I cleaned out the carburetor & jets and have a new fuel pump. I don’t think it’s a fuel problem because I tried pumping the fuel line bulb when it couldn’t start and there wasn’t any difference. I'm thinking that it may be the computer that is going bad. Can you help me?"
